Hi, I'm new to this site.
I am building a robotics controller for part of a junior design project at university. I am studying mechanical engineering, and would appreciate any input to this question:
Anyway, my robot has 4 servos. I am using potentiometers from a model airplane controller to adjust pulse width for speed and direction control of modified servos. Anyway, I plan to use one 555 timer in astable mode setting a clock frequency of 50hz, triggering monostable 555's which set the pulse width. I'm sure you are familiar with this type of application. On to the question:
Will it be okay to use a single astable 555 to trigger all 4 monostables, or do I need to set up an astable/monostable combo using a 556 chip for each servo? To reduce parts count and space in the controller, i'd like to use a single astable 555 and combine the 4 monstables on 2x 556 ICs. opinions will be greatly valued.
Thanks!
Thanks!
