Hi friends.
I have been trying to debug an 8251 UART for 5 days now. In fact 3 of them and they all error the same way. I got 1 from a different source, and the last 2 from a single source.
The problem is when receiving characters from my PC, into a simple system with a CPU + UART.
Most characters are received correctly, but 1 out of 10 or so chars are junk.
I have set up the USART for asynchronous communications, 8 data bits, 1 stop bit, no parity.
I configure Putty for the exact same setting.
I have even tried to test the USART on a breadboard, and do it manually. I still get the same issue.
I am initializing the USART correctly I think, the mode byte is 0x4D, and command is 0x37. This is exactly for 8 data bits, 1 stop, no parity, etc.
I am out of ideas, and this is driving me nuts. The issue was happening with my first 8251, so after a while I assumed it was damaged. Bought another 2. Same issue.
Same issue whether when USART used with CPU, or breadboard.
The only thing I can think of is that I am initializing it incorrectly, but that would be unlikely. I have tried many many times.
If someone has any ideas please let me know. I am getting desperate now.
Thank you and best wishes
Paul
Paul
