K
Kevin Walton
Hi
I have linked up a MPX 4115 pressure sensor
[http://e-www.motorola.com/webapp/sps/site/prod_summary.jsp?
code=MPX4115&nodeId=01126990368716]
via a MAX 188 12 bit ADC
[http://dbserv.maxim-ic.com/quick_view2.cfm?qv_pk=1070]
to a PIC 84A.
The ADC is using a 5v reference (supply voltage) rather than the
internal 4.096v reference as ground preasure output of the MPX 4115 is
greater than 4.095 volts.
The measurments are very noisy though, a summary of 5000 readings over
15 mins:
meters adc output
max 536.79 3,472.00
min -131.45 3,176.00
mean 97.74 3,368.43
median 87.29 3,373.00
range 668.24 296.00
std dev 69.73 31.11
variance4862.00 968.00
and the graph in Excel:
http://mach.unseen.org/~kevin/electronics/altimeter/altitude1.jpg
Using the sugested filtering circuit from Motorola at:
http://e-www.motorola.com/files/sensors/doc/app_note/AN1646.pdf
It smooths the readings pretty well (although still not giving the 1m
resolution I would like):
meters adc
max 78.36 3,391.00
min 47.18 3,377.00
mean 70.31 3,380.61
median 73.90 3,379.00
range 31.19 14.00
std dev 6.52 2.93
variance42.50 8.56
http://mach.unseen.org/~kevin/electronics/altimeter/altitude2.jpg
but causes a large skew in the data both as an ofset throughout and a
'charging' curve at the start - the picture explains a thousand words
Have I done something wrong, missed something?
Ideally I would love an answer of 'this is how you get better than 1
meter resolution', but I'll appretiate all the help avaliable to solve
the 'skew' problem that is causing me most grief.
Kev
to a PIC 84A.
15 mins:
meters adc output
max 536.79 3,472.00
mean 97.74 3,368.43
range 668.24 296.00
std dev 69.73 31.11
meters adc
max 78.36 3,391.00
min 47.18 3,377.00
mean 70.31 3,380.61
range 31.19 14.00
std dev 6.52 2.93
variance42.50 8.56
Kev
