MPEG2 Audio and Video Splitter
I am using an Altera FPGA to split video and audio data from an *.mpg
file. I receive mpg data and send to a IP MPEG2 Decoder Core
purchased from Amphion Semiconductors. I have attempted to code a
data splitter but have plenty of questions with the demultiplexing of
the data.
The below describes the code at higher level:
if (prefix_code_recognized) // received 24'h000001
start_code <= next_data_byte;
if ((8'h00 <= start_code <= 8'BF) ||
(8'hE0 <= start_code <= 8'hFF))
video_start_code <= 1'b1;
if (8'hC0 <= start_code <= 8'hDF)
audio_start_code <= 1'b1;
Once I have decoded a video start code, I send all data to the Video
Decoder, until I recognize a prefix followed by an audio start code,
when I then send data to the audio decoder core until Video start_code
is recognized.
To test my splitter I input an mpg file into the stimulus and split
the data out, writing the video contents to a file. I then convert
the dump file to an mpg file and play in media player. If the
splitter is working, then the file would play w/out sound. However, I
only get a black screen which tells me the code is not functioning
correctly.
Can someone please point me in the right direction? Thanks.
Amit
Ben Jackson
file.
What is the format of your *.mpg file? It is almost certainly either
a mpeg2 transport stream or a packetized elementary stream. Either way,
you will find start codes inside, but you will be looking "inside"
the TS or PES packets and your output will be a hash.
A TS will start with 0x47 (and repeat every 188 bytes). I forget if
there's anything special about a PES, but knowing it exists is half the
battle. Either one will have enough information to allow you to split
the file at a higher level than the individual start codes.
BTW, are you the Amit Patel I know?
Hello Ben,
Thank you for your response. I believe the data is PES, because the
stream starts with a start_code of 32'h000001BA. I am using an IP
MPEG2 Video Decoder in my design, and I need to split the mpeg2 video
and audio data. I am doing so as shown above, but am still uncertain
if this is the proper way to transmit the data. Do I have to go by
the packet information and count my data? Below is a C++ description
I am following. Let me know what you think. Thanks:
#include <windows.h>
#include <stdio.h>
#include "MpegStream.h"
void MpegWrite(char* fname, HANDLE hFile, LPBYTE base, DWORD len,
LPDWORD count, BYTE c)
base[*count] = c;
if (++*count >= len)
DWORD dwBytesWritten;
if (!WriteFile(hFile, base, len, &dwBytesWritten, NULL))
LPVOID errmsg;
FormatMessage(FORMAT_MESSAGE_ALLOCATE_BUFFER |
FORMAT_MESSAGE_FROM_SYSTEM, 0, GetLastError(), 0, (LPSTR)&errmsg, 0,
NULL);
fprintf(stderr, "WriteFile %s failure (%d) %s\n", fname,
GetLastError(), errmsg);
LocalFree(errmsg);
ExitProcess(1);
*count = 0;
int main(int argc, char* argv[])
LPVOID errmsg;
BYTE cMpegBuf[1024];
BYTE cVideoBuf[1024];
BYTE cAudioBuf[1024];
LPBYTE lpMpeg;
DWORD dwMpeg;
DWORD dwVideo;
DWORD dwAudio;
DWORD dwVES;
DWORD dwAES;
// check command line arguments
if (argc != 4)
fputs("Usage: MpegSplitter <input MPG> <output video> <output audio>
\n", stderr);
ExitProcess(1);
// open input MPG file
HANDLE hMpeg = CreateFile(argv[1], GENERIC_READ, 0, NULL,
OPEN_EXISTING, 0, NULL);
if (hMpeg == (HANDLE)INVALID_HANDLE_VALUE)
NULL);
fprintf(stderr, "CreateFile %s failure (%d) %s\n", argv[1],
LocalFree(errmsg);
ExitProcess(1);
// create output video file
HANDLE hVideo = CreateFile(argv[2], GENERIC_WRITE, 0, NULL,
CREATE_ALWAYS, 0, NULL);
if (hVideo == (HANDLE)INVALID_HANDLE_VALUE)
NULL);
fprintf(stderr, "CreateFile %s failure (%d) %s\n", argv[2],
LocalFree(errmsg);
ExitProcess(1);
HANDLE hAudio = CreateFile(argv[3], GENERIC_WRITE, 0, NULL,
if (hAudio == (HANDLE)INVALID_HANDLE_VALUE)
NULL);
fprintf(stderr, "CreateFile %s failure (%d) %s\n", argv[3],
LocalFree(errmsg);
ExitProcess(1);
// split mpeg into video and audio
lpMpeg = cMpegBuf;
dwMpeg = 0;
dwVideo = 0;
dwAudio = 0;
dwVES = 0;
dwAES = 0;
int state = 1;
while (1)
// if need mpeg data
if (dwMpeg == 0)
if (!ReadFile(hMpeg, cMpegBuf, sizeof(cMpegBuf), &dwMpeg, NULL))
NULL);
fprintf(stderr, "ReadFile %s failure (%d) %s\n", argv[1],
LocalFree(errmsg);
ExitProcess(1);
if (dwMpeg == 0)
break;
lpMpeg = cMpegBuf;
// process mpeg data
switch (state)
case 1 : // look for first byte of start code
if (*lpMpeg == 0)
state = 2;
else
MpegWrite(argv[2], hVideo, cVideoBuf, sizeof(cVideoBuf), &dwVideo,
*lpMpeg);
MpegWrite(argv[3], hAudio, cAudioBuf, sizeof(cAudioBuf), &dwAudio,
*lpMpeg);
break;
case 2 : // look for second byte of start code
if (*lpMpeg == 0)
state = 3;
else
state = 1;
0);
*lpMpeg);
0);
*lpMpeg);
break;
case 3 : // look for third byte of start code
if (*lpMpeg == 1)
state = 4;
else if (*lpMpeg != 0)
state = 1;
0);
0);
*lpMpeg);
0);
0);
*lpMpeg);
break;
case 4 : // have start code. process start code
// if start of video elementary stream
if (*lpMpeg >= VIDEO_ELEMENTARY_STREAM &&
*lpMpeg < VIDEO_ELEMENTARY_STREAM + 0x10) //
VIDEO_ELEMENTARY_STREAM == 0xE0
state = 5;
0);
0);
1);
*lpMpeg);
// if start of audio elementary stream
else if (*lpMpeg >= AUDIO_ELEMENTARY_STREAM &&
*lpMpeg < AUDIO_ELEMENTARY_STREAM + 0x20) //
AUDIO_ELEMENTARY_STREAM == 0xC0
state = 8;
0);
0);
1);
*lpMpeg);
// if none of the above
else
state = 1;
0);
0);
1);
*lpMpeg);
0);
0);
1);
*lpMpeg);
break;
case 5 : // here for MSB of VES byte count
dwVES = *lpMpeg << 8;
state = 6;
*lpMpeg);
break;
case 6 : // here for LSB of VES byte count
dwVES |= *lpMpeg;
state = 7;
*lpMpeg);
break;
case 7 : // here to copy VES data
if (--dwVES == 0)
state = 1;
*lpMpeg);
break;
case 8 : // here for MSB of AES byte count
dwAES = *lpMpeg << 8;
state = 9;
*lpMpeg);
break;
case 9 : // here for LSB of AES byte count
dwAES |= *lpMpeg;
state = 10;
*lpMpeg);
break;
case 10 : // here to copy AES data
if (--dwAES == 0)
state = 1;
*lpMpeg);
break;
// decrement mpeg buffer count
lpMpeg++;
dwMpeg--;
// close files
CloseHandle(hMpeg);
CloseHandle(hVideo);
CloseHandle(hAudio);
return(0);
