Hi.
My NiMH 4xAA cell charger is manufactured by "Duracell", the rechargeable batteries I bought are "Energizer recharge" 2300mAh each, ACCU NH15 1.2V NiMH - HR6.
I have started using rechargeable cells with this recently bought charger as my power-hungry DSLR Pentax eats alkalines at an alarming rate.
Over the weekend, I had used the rechargeable batteries, so was recharging them over several hours, checking every so often that cells and charger weren't getting too hot.
The charge started with LED's red, as cells were depleted, then later turned to green.
To give them an extra boost, I left them for longer in the charger.
Later, a loud bang from charger, both LED's gone off.
Unplugged and checked cells - all 4 OK.
Opened charger and found mains fuse is OK, no blown caps or resistors, but MOV at mains input reads open circuit (OL) on ohms scale.
Shouldn't a good MOV be a low reading, like the fuse?
I plan to get another charger, and/or or replace the MOV, but first:
What could cause the MOV to blow -
too long on charge?
wrong cells (charger specifies to use NiMH)?
could the 2300mAh capacity rating be too heavy for the charger (then surely the secondary cct would have gone haywire - not primary input)?
too long on charge?
