Simply I can't get it to work. When I continuity test across it's lugs it shorts. disconnect one wire and it shorts across the brushes. I'm unsure if this is normal. It's a Parvalux some of you helped me get a correct power supply for a couple of years back. Spec: dc 24v. amps 8. 120w. rpm 2800. 12/14 geared. I'm looking inside the back of the motor and it sure seems grubby in there. If I do get it working it might be worth a bit of tlc.
Darren
Darren
