Hi everybody,
I am not too good in electronics, that is why I ask you for an advice. For my Study I have the following dilemma:
I have designed a pipesystem, in this system a fluid will flow. But the fluid needs to be dosed. To do this there are some valve in the pipe(these can either be rotational valve or linear)
As mentioned in the titel, I am doubting to pick a motor or a solenoid(soft shift?) The choice has to be based on reliability/price/accuracy
Some points are:
- Fluids are under 3bar/40psi pressure,
- The valve can be rotational or linear,
- The solution has to be affordable, reliable and accurate.
The problem is that my knowledge is not sufficient to make a decent choice. I hope some of you can help me?
Thanks in advance,
Hendrik
Some points are:
Thanks in advance,
Hendrik
