mike
Trying to control a 12V 5A motor from the parallel port. I have to control
ten of them, so I'm trying to get away without using expensive relays or
optoisolators ($20-$30 each). I found a monolithic darlington transistor
rated at 10 amps, already including reverse-current diodes and appropriate
resistors, perfect for my application (so it seems).
I'm planning on hooking up a low current cheap optoisolator/interrupter to
drive this transistor from the parallel port (albeit high voltage isolation)
so I have a good chance of not frying the computer if one of the motors
overheat or blows. Would this work for my application?
Any help would be appreciated.
Please see:
http://rocky.digikey.com/WebLib/Fairchild/Web Data/TIP140_141_142.pdf
Thanks!
Please see:
Thanks!
