Hello,
First of all, my analog multimeter can turn an LED on by putting a - lead to the anode and a + lead to the cathode, and can't do so if I swap them. As a consequence, I just remember that the + lead and - lead are actual + and - only when they measure a voltage of a load, which receives power from another voltage source. On the contrary, in powering an LED on, the analog meter is acting like a voltage source, so I the - lead is, in fact, the + of a voltage source and must be connected to the anode.
My first question is that is my understanding correct?
Second, I put my - lead to the source and + lead to the drain of a newly bought MOSFET without any uses before. This reads 5 ohms. Subsequently, I swap those leads and get 200k reading.
My second question is that why the resistance in the first measurement is so low, even I've shorted gate-source together once before.
Thank you
BlackMelon
Thank you
BlackMelon
