MOSFET to replace a relay
I need to replace a relay with a MOSFET. The relays have very low contact rating is 30milli ohm. I need to switch low value resistors typically 0.2R.
I am measuring currents in the 2uA range, so can't afford that to be affected.
The relays are controlled from a PIC micro. Is there any MOSFET I could use?
Best regards,
Raj
If the voltage is low, there are many options. Some as low as single digit milliohms.
For such low currents I cant see the resistance being a huge issue. Are you really concerned with nanovolt differences in voltage?
