Mosfet selection for switching a solenoid
Hi
I need help for the selection of suitable mosfet (TO-220 package) for switching a solenoid with following parameters:
Switching Frequency = 16 Hz
On time = 20ms
Off time = 41ms
Duty Cycle = 32.78%
Operating Voltage = 12V (for driver and solenoid)
Solenoid Inductance = 1.2mH
Current = 2.6 - 3.0A
Also the value of the gate resistor for the mosfet.
KrisBlueNZ
Sadly passed away in 2015
Do you want an N-channel or P-channel MOSFET?
What supplier?
There's a very wide range of MOSFETs that will be suitable.
Here's a list of suitable N-channel devices from Digi-Key in order of ascending price. The main difference between them is RDSon and manufacturer.
http://www.digikey.com/product-detail/en/PSMN022-30PL,127/568-7512-5-ND/2606361
http://www.digikey.com/product-detail/en/PSMN017-30PL,127/568-9506-5-ND/3152043
http://www.digikey.com/product-detail/en/FDP8880/FDP8880FS-ND/976840
http://www.digikey.com/product-detail/en/IRFB7546PBF/IRFB7546PBF-ND/4772484
http://www.digikey.com/product-detail/en/IPP065N03L G/IPP065N03LGIN-ND/1996760
Thanks for your response.
Any N-Channel device from any supplier which match the parameters. I have tried 2SK1388 but it would get fairly warm. Next I am planning to try NB59N10D, IRF540, IRFZ24N, and IRFZ44 (which I already have with me).
Keeping in view the operating voltage 12V and current 3A, actually I wanted to know what RDS(on) value would be the most suitable so that the heat dissipation is minimum.
The lowest one.
Edit: When switching at 16Hz, the gate capacitance is not going to matter, at much higher frequencies it would.
Bob
KrisBlueNZ
Yeah, what Bob said.
A TO-220 package doesn't need heatsinking if it's dissipating less than about 0.5W. You can calculate the maximum allowable RDSon from the power and the current:
R = P / I2
= 0.5 / 32
= 56 mΩ
All of the devices I suggested in post #2 have RDSon < 56 mΩ at VGS = 10V.
