Rubicon
Hello,
An old project that I'd been working on is that of an electric fishing
Kontiki. I have a circuit that I think will work O.K. but I hope that
someone could take a look at it and point out any glaring mistakes.
In particular the mosfet motor driver circuit is of concern to me.
http://www.geocities.com/talionis.geo/Temp/temp.html
The servo retract button and timeset reed switch are on the same input
as when the PIC starts up it first checks that input to determine if
it should continue with the startup sequence or simply retract the
release mechanism into the casing. The DPST switch is to ensure rough
waves don't accidentally activate the servo button when in timeset
mode.
The seperate voltage regulator for the servo is to hopefully prevent
any brownout reset of the PIC should the servo need to draw alot of
current if the release mechanism is under load or maybe jammed.
The seconday lines to the servo are in case of PIC failure or bad
programming to allow me to control the servo, retract the release
mechanism and get the whole thing out to be fixed.
The two reserved PIC I/O pins are for a strobe circuit I may add
later. If not then I'll rearrange things on Port A to and figure out
how to allow the PIC to sample the battery voltage six times a minute
and average it for a more accurate reading.
The zener diode I meant to remove before making the page but I do need
to ask if the mosfet needs any over-voltage protection.
Any help is greatly appreciated.
Thanks,
Rubicon.
mode.
Thanks,
Rubicon.
