Hi all. I'm trying to use a microcontroller's PWM (i.e. logic level out) to drive a high side N-channel MOSFET (source follower) and thereby provide a higher voltage (30V), higher current (up to 5A) PWM supply to a resistive load (heater filament).
Block diagram:
http://dl.dropbox.com/u/32751654/PWM driver block diagram.png
Please tell me if I'm going down a blind alley.
Having a look at the available MOSFET gate driver ICs, they seem to be mostly intended as half H-bridges for motor control or for controlling switched mode power supplies. One I have seen is National Semiconductor LM5109 http://www.national.com/ds/LM/LM5109B.pdf
Would I be able to use just the high side half of this IC for my purpose? Will it still work without the low side connected to a MOSFET? The datasheet says "Unused LI input should be tied to ground and not left open", so presumably it can be, but something else I read seemed to imply that the low side MOSFET is necessary to keep the bias voltage on the bootstrap capacitor.
Can someone please confirm that this is a sensible way of translating a logic level PWM signal to something that can drive these voltages and currents, and whether or not I could use this IC in this way? If not, any suggestions for a different driver circuit or IC suitable for a high side PWM would be appreciated.
Cheers,
Matt
Block diagram:
Cheers,
Matt
