andy
I'm using a BUZ10 n-channel mosfet to switch a 1 ohm electromagnet coil on
and off. It's been working OK for a while, and is now stuck open with a
resistance of 11 ohm between drain and source, and around 50 ohm between
gate and drain or source. Any ideas on what might have caused this? It's
unlikely to be electrostatic damage, because there is a 10k resistor
permanently soldered between gate and source, which was there before is
started malfunctioning.
It has a heatsink on it - an aluminium screw-on one about 4cm square with
4 fins on it. Can't find the C/W rating for this.
