Hello all, I am using a small module like the one in this link:
https://www.aliexpress.com/item/Tri...or-Industrial-Control-5V-36V/32751789827.html
I have, for simplicity sake, a 2 Ohm coil of 20AWG wire load hooked up to the output.
I am also using the Adjustable Power Regulator in this link to vary the current output:
https://www.aliexpress.com/item/LCD...meter-Ammeter-Current-tester/32654445678.html
When I set the current output on the regulator to 5 amps, the MOS power transistors stay relatively cool.
The voltage drops to 10 Volts to regulate the current, i.e. 10V = 5A * 2 Ohms
When I set the current output on the regulator to 2.5 amps, the MOS power transistors heat up to the point where you could literally fry eggs on them.
The voltage drops to 5 Volts to regulate the current, i.e. 5V = 2.5 A * 2 Ohms
Just wondering why the voltage drop leads to such significant heat increase on the MOS transistors when, in fact, they are outputting less current?
I have tried using 12Vdc and 24Vdc power to the regulator but no change.
Thanks for any ideas anybody...
