N_Cook
Video projector without an IR R/C , originals or substitute not available
and cannot access the presets.
Setting a One-for-all so-called universal, URC 3445 in search mode ellicited
nothing in TV/VCR/Sat/DVD sub sets, as usual. What is not specifically
stated in the URC manual is after setting in search mode , why you press
power button, and then + to advance through the presets in the firmware, to
send power on/off codes.
I forgot to press Power in the DVD subset sequence and instead of
transmitting variously coded Power codes it must have sent various + codes.
Anyway on DVD code 1928 the "Keystone +" box popped up on screen. The "-" ,
Power , or no other button worked in this DVD subset mode. I intend getting
into the URC, remove ceramic resonator, and putting about 2V rms of sig gen
around the resonant frequency (done this before on a different URC) and see
if that opens up more buttons , set on 1928.
Failing anything more useful from that, monitor that "+" sequence on digital
storage scope should give the "50 KHz" pulse rate , coding clock rate and
combined model+code sequence for "+".
Then something like this circuitry of settable clock + CMOS switch settable
PISO shift register for model code (HCT165 ?) / settable delay SR (4557?) /
another settable PISO for buton code / gating a settable "50 KHz "
oscillator / IR diode / ( learnable remote for regular use ).
Changing switch settings for the button PISO from the known working "+" code
to the missing ones particularly for MENU and ENTER functions in particular
.. Any flaws in this potential hack, as only thought experiment at the
moment?
ps , for the UK anyone know what is the cheapest souce of very basic
learnable remote controls?
moment?
