You're most welcome. No oil injection. The book lists 50:1. I use the
Northern tool smokeless synthetic oil at 80:1. There is just a tiny bit
of
smoke when it cranks but then it goes away as the muffler gets hot. There
is
still the smell of oil in the air but it's not bad with that kind of oil.
The northern oil comes in little bottles good for 1 gallon of gas at 40:1.
I
simply use a 2 gallon tank. I've been running it that lean since new and
the
thing has thrived. The exhaust pipe is clean and no black mung oozes out.
It
probably uses less oil than an air cooled 4-stroke of similar size.
One nice thing about this generator being engine-limited instead of
generator-limited is that more power is available with a few simple engine
mods. I have two of these and I'm thinking about buying a third to take
apart
and see what kind of hotrodding that can be done. I'd love to get 1500
watts
out of it. That would be a very convenient output. Enough to run just
about
any heating appliance at full output but still in a light package.
I can't believe how handy having a generator in the trunk is. I've had an
inverter installed in my car for years but for any serious load, the
engine
needs to be running (no aux battery) and that means leaving the car open
to
theft in bad areas.
Just the other day I went with a friend to look at a building he was
considering buying. No power. I got the generator out, along with the
100 ft
of 18 ga extension cord, a multi-outlet strip and a couple of CFL-powered
work
lights. that gave us each a light. We explored all over the building,
taking
a couple of hours.
My car would have idled away probably a gallon or two of gas. The
generator
barely sipped the gas away from the filler neck. The building was larger
than
the 100 ft cord would cover so I just carried the generator from area to
area,
sitting it outside whenever possible. Flashlights would not have done the
job. Coleman lanterns would have but I'm loathe to carrying open flame
into
someone else's unknown property.
I treat the generator as an infinite extension cord capable of 1000 watts.
Microwave oven at a picnic? NO problem. Power an amplifier for a band at
a
camping party? NO problem. Need heat after a breakdown while waiting on
the
wrecker? No problem. Best C-note I ever spent.
John
John De Armond
See my website for my current email address
http://www.neon-john.com
http://www.johndearmond.com <-- best little blog on the net!
Tellico Plains, Occupied TN
Better to pass boldly into that other world in the full glory of some
passion
than fade and wither dismally with age. -Joyce
