Hi All ...
I'M BaaacK !!!
Got a new conundrum for Y'all to twist yer brains around here today ... as usual ... NO schematics or service manual available ... Luke Skywalker troubleshooting scenario ... AGAIN ... use the FORCE Luke !
A client brought me this set of studio monitors made by Monster with a major problem ... no power up.
After a bit of poking around with a DMM, I found the woofers amplifier chip to have multiple shorts where there should be none. So my 1st action was to replace the STA516B amp chip and after installed and powered up ... still no power up and blew ( as far as I can tell ) again ... the woofer amp chip.
After this happened, I took a closer look and saw that on the original (blown chip) I removed there were some missing pins. When removing it I did not notice or see any broken pins floating around the work area. Inspecting the original chip under high mag ... it looks like they were left OFF the chip at manufacture of the chip ... NOT just cut off before placement & reflow.
SO back to the troubleshoot mode ... I found the 3.3V regulator had a short between output and GND. After using the FORCE, I decided to remove the STA309A multi-channel digital audio processor and found this was the OFFENDING component that had the short ... lucky guess ? ... NO I used the FORCE Luke !!!
SO ... I ordered another amp chip and the new STA309A ... after I placed the new STA309, I decided to see if it would power up BEFORE I placed the 2nd new amp chip and lo & behold ... we had power up and sound from the tweeter ... YAHOO !
After this, I placed the 2nd new STA516 with the missing pins on the original ... LIFTED so as not to be connected as per the original missing those pins. And those pins were the 4 Vcc pins that you can see in the datasheet block diagram here ... Vcc-1A, Vcc1B, Vcc2A, Vcc2B ...
So as I can see from this block diagram ... IF all the Vcc pins are NOT connected ... this thing SHOULD NOT function ... The tweeter side that WORKS ... have all these pins intact and connected to the voltage source that feeds the tweeter Vcc pins, and are connected to the main power supply that outputs 34VDC as seen in the partial schematic I drew up here ... keep in mind this is the woofer side which I am trying to troubleshoot ...
So as one can see there are some notes about some findings ... the one that is of import was the C4 cap that had a 1K short to GND and so was replaced. I'm hoping/thinking that this cap possibly could have been the reason for blowing the amp chip ... who knows ...that cap is from Vss-SIGN to GND on the input side which would be the left side on the diagram ... pin 36 thru cap to gnd.
So ... after I blew the 2nd amp AGAIN ...I decided to draw up a schematic and just get a better idea of how the output was configed and that's when I found the defective cap.
So my BIG question is ... why would those missing pins for Vcc be missing on the original chip ?
And why when I installed new chip number 2 blow up if those pins were supposed to be OMITTED ... and lifted after I installed it that way and it blew up ?
I just can't see how this amp could work missing the Vcc connects ???
It doesn't make sense without a positive Vcc supply for the internal FET's ...
There are 2 configs that this chip can work in via the CONFIG pin either being grounded or tied high ? In one config it uses more current for more power OR in other config less current HALF power.
As far as I can tell ... CONFIG pin IS at gnd and is working in full power mode.
Refer to full datasheet here ... and see schematic as I ringed it out with the DMM.
https://www.st.com/resource/en/datasheet/sta516b.pdf
So far at this point ... I am waiting to place another NEW amp chip until I find whatever it is that is blowing this chip ... so far that one cap I found that had a 1K ohm short to ground is the only glitch I have found so far.
It seems that there may be something on the output AFTER the coils (22uH) that may be causing a problem but I haven't found anything at this point ... I'm still leaning towards that bad cap on a power rail that may have been the problem.
There is no dead short or small or large resistance across the output terms .... at this point I'm stumped for now ...any ideas would be appreciated ...
As far as the filters go ... the cap values are irrelevant except for one cap that got lost in the carpet.
But I'm sure that because both sides are mirrored ... I can find the right value to replace ... I think it's just a bypass or part of the crossover filter(s).
They are all caps from signal to ground so shouldn't be an issue ...
Journey
I'M BaaacK !!!
Journey
