MONITOR: Repair, screen blank, though LED glows...
drake
I'd posted before about broken connector pins... I think one of the
replies stated that was not the problem. I investigared by cutting off
the connector cord from a trashed monitor, and experimented with
breaking the pins...
it seems that when a pin is broken, its end is still in the connector,
and blocks the entry of any other pin. This was not so in my monitor's
connector.
The 4 pins missing had proper holes... plus it seems those slots were
supposed to be empty ot unnecessary.
The problem:
When I switch on the comp, there is no picture whatsoever on the
monitor screen. I know it did not get power coz I did not hear the
static. There is no problem with the rest of the comp/VGA card.
However, the Green LED (there are no other) lights up, and nothing
else happens. It does not blink, and there is no beeps from the
monitor.
Its a TVM LG4R 14" VGA monitor.
What could the problem be?
Is it advisable for me to open the monitor? If so, what are the
obvious clues i should look out for?
I would appreciate any advice.
TIA,
Lars
Dave D
drake said:
connector.
Well, you were told as such, but you didn't seem to accept it :)
The problem:
monitor.
I know of no monitors which beep.
It could be virtually anything. Failed PSU, failed HOT, no heater voltage,
there is no way of telling from the information you give.
I would never advise anyone without experience of TV and monitor servicing
to try a repair of this nature. A professional repair on a 14" monitor is
unlikely to be cost effective, and the chances of you fixing it yourself are
slim. The first thing to look for in this case would be a failed HOT or PSU
fault, but don't expect advice like 'change Tr512' or 'check r213 for open',
it just isn't that simple.
Dave
