Module or card Grooved Slides for customisable rackmount nest enclosure
Jim Gregory
Looking for more of these - rather difficult to describe in brief - make
unknown, maybe Vero.
These sturdy, moulded guide ribs are made from black nylon/PTFE, fully
grooved 2mm wide & deep, with an optional, embedded, square 4BA or M4 nut at
front - for securing a threaded puller. The groove funnels out at its front.
Toward each end is a 2.5mm slit stud in a well, behind the rib groove, to
locate and engage where needed in the perforations of steel inserts trapped
in the front and rear extruded ali profiles (different) across the nest,
this pair is set 187mm apart.
The slide grooves accept the raised longitudinal "fins" of modules that
glide in - two fins above, two fins below - or the same grooved "guides" can
be used just for keeping full-height cards in place.
Length of each runner/guide 252mm
Width along 187mm body nearly 6mm, over ali extrusions 9mm
Height 9mm
Distance between locating studs 213mm
Does anybody know where can I get another 24 of these, please? Thanx in
advance.
Jim
