dave
I've got an APC Back-Ups ES500 UPS that I had modified to use a pair
of 220AH 6V golf cart batteries instead of the 7AH battery that's
inside the UPS.
It works, but there are a few things that concern me. It's using a
240V AC 50 amp circuit breaker between the batteries and the UPS, and
it makes a buzzing noise when it's under load. Is this safe? I'm not
using it right now because I don't think it's right.
I'm looking for an appropriate DC fuse and cut-off switch, but the DC
fuse is not easy to find. Is there generally any sort of
short-protection for the batteries built into the small APC UPS? Would
it be ok to not use any fuse?
The UPS has a 300 watt inverter, but I'm thinking it may place a
larger load on the batteries. Would a 30 or 40 amp blade-type
automotive fuse be ok for this?
I also have a larger 12 amp battery charger that I'll use to recharge
the batteries after a long power outage. Right now I'm cutting off
the batteries and unplugging/turning off the UPS during charging. If
I left the batteries connected and the small internal UPS charger
going while using the external charger, would it cause problems?
inside the UPS.
