I often have need for more than one meter on breadboard projects. I modify the leads with pins that fit smoothly into the breadboard. Jameco part number 185421. Cost about $0.07 each purchased in quantity of 10. Crimp, solder and heat shrink.
Favorite meter currently is from Electronic Goldmine. Large display digits, about 1" tall. Short on the AC Volts scale, only two settings. But also has a 60 Hz square wave output/ Otherwise has the usual hFE scale and 10 Amp DC and semiconductor settings. Not bad for $5.00. MM2003 by SE.
