Mitsubishi VS-5071 no picture has sound.
Mitsubishi VS-5071 projection TV (in a good shape) has no picture, but
receives sound fine.
Nothing comes up. The tuner works but the menu (OSD) is not accessible.
The tube filaments are lit up.
Would the problem lie in the vertical circuits or the PiP module?
Any ideas are greatly appreciated.
Thanks. Mike.
Shoreline Electronics
This model does not have the typical PIP problems like the VZ1B and VZ2
chassis.
If you have no HV or sweep, then the vertical circuit is a good
cause....blah blah blah.( I'm tired!)
Check this tip :
Text pasted from WinSTIPS 2.0
http://www.ServiceSoftware.com
MITSUBISHI V13
Raster No Go. Has Sound And Hi Voltage (No Vertical)
Bryn Mawr TV
R510 Fuse Resistor (Off Pin 5 Of Flyback) Opens For No Reason (1.2 Ohm 1/2w
/103p398010)
Replaced Vertical Ic (La7838) Ic401 For P.M
MITSUBISHI V13
Shutdown. Loud Pop Then No Raster Has Sound And Hi Voltage (No Vertical)
Bryn Mawr Tv
Hole In Ic401 (La7838) Open C406 (100uf /35v) Open R510 Fuse Resistor (Off
Pin 5 Of Flyback) (1.2 Ohm 1/2w /103p398010)
Jeff Stielau
Shoreline Electronics Repair
344 East Main Street
Clinton,CT 06413
860-399-1861
860-664-3535 (fax)
[email protected]
