sofie said:
Gail Storm:
It is probably a broken plastic guide on the pinch roller assembly and not
bad rubber.... this is a high failure part on most Mitz VCRs that use this
part. You might try another supplier like TriTronics or Fulton Radio....
go to thier websites and/or call them.
Best Regards,
Daniel Sofie
Electronics Supply & Repair
Thanks Rono. I did clean the part with sandpaper and it is working now. I would
be nervous to use acetone. That doesn't harm the rubber?
And thank you sofie. The plastic guide is OK it was the rubber part. Heavy use
for about 4 years and it would record OK but horizontal lines on play back.
Cleaned up pinch roller and it works again. Don't know how long it will work so
I am looking for a replacement part. The two web sites were unknown to me. I
will give them a try. I appreciate the help.
