MikroC programming problem
I am using PIC16F877A to build a Ultra Sonic Sensor. i fail to compile my program due to some error.
can anyone tell me the function of MOVF because i cant find any relevant info from the mikroC manual.
i have uploaded my program and the error during compile. any idea about whats going wrong?Untitled.jpg
View attachment code.txt
jackorocko:
i am trying to modified the program of others.
according to the compiler, it stated "undeclared identifier 'STACK_2' in expression"
but i din have idea what the STACK is, either it is a register inside the PIC or a variable that we need to create by ourself.
any idea?
I would say you need to create it. It must have been someone else's constant variable if they followed standard convention. But I am not really sure what the code is trying to do, so I don't really have a guess on what the variable would have been exactly.
I don't know too much asm
I believe the MOVF instruction is an assemble lang. type of instruction. The MikroC
is a high level lang. you can't mix the two lang.
