Micronta 22-167/220-0167
After cal, the above mentioned DMM failed three ACV ranges. Anyone know where I can find an adjustment procedure? There are three potentiometers, but the rest of the test points are good, so I'd rather not go tweaking blindly.
Thanks in advance for your help.
-CT
davenn
-CT
Im personally not familiar with the brand.... have you googled the manufacturer to try and get service info ?
Dave
Thanks for your responses.
I have googled a number of search strings with no luck. The closest I got was a Radio Shack archive that contained a Spanish manual which just tells you how to operate a multimeter.
On that note, Micronta is indeed under Tandy (as is Radio Shack)
