Microcontroller reset condition
Dummy
RESET pin is active low.
During powering up, the RESET pin is being pulled high.
I encounter a situation where under certain condition, microcontroller
resets without any glitches observed at RESET pin which is still HIGH
at 3.3V. The sytem resets itself, and I assume that's because of
microcontroller resets.
So I was wondering whether RESET pin needs to be driven low before
resetting? Any other forms of reset that doesn't need a low on RESET
pin?
Paul Burke
pin?
What uC ? Power glitches? Someone else mentioned watchdog. Does this uC
have illegal opcode trap? Have you forgotten to enclose the program in a
while(forever) loop? Is your test gear fast enough to see all relevant
glitches? Is it really a reset, or is it just vectoring to the restart
routine via say an uninitialised interrupt vector?
Paul Burke
maxfoo
pin?
Just solder a 1K resistor in series from reset pin to Vcc and be done with it.
Remove "HeadFromButt", before replying by email.
Martin Riddle
most likely the watchdog timer. disable it in the configuration settings.
