being a novice I've had many problems with adopting a small test-driver of an LCD for PIC18F4550. Now much further from some days ago by the help of various great people of forums, but still get errors for things I don't know about the C18 compiler I'm using.
I'll provide the current error I have, hope someone help me go one step further with it. Also, I see in link statement "E:\mcc18\h", while I don't have such folder, but in "C:\mcc18\h", and I can't find from where in Microchip IDE to edit this.
I also attach the program and its other header files.
Please help if possible!
Code:
Release build of project `C:\Documents and Settings\WHW\Desktop\prj\LCD_X\lcd4550.mcp' started.
Mon Sep 20 08:29:04 2010
Clean: Deleting intermediary and output files.
Clean: Deleted file "C:\Documents and Settings\WHW\Desktop\prj\LCD_X\lcd-4550.o".
Clean: Deleted file "C:\Documents and Settings\WHW\Desktop\prj\LCD_X\lcd4550.mcs".
Clean: Done.
Executing: "C:\mcc18\bin\mcc18.exe" -p=18F4550 /i"E:\MCC18\h" "lcd-4550.c" -fo="LCD-4550.o" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
C:\Documents and Settings\WHW\Desktop\prj\LCD_X\lcd-4550.c:135:Warning [2054] suspicious pointer conversion
C:\Documents and Settings\WHW\Desktop\prj\LCD_X\lcd-4550.c:136:Warning [2054] suspicious pointer conversion
C:\Documents and Settings\WHW\Desktop\prj\LCD_X\lcd-4550.c:138:Warning [2054] suspicious pointer conversion
C:\Documents and Settings\WHW\Desktop\prj\LCD_X\lcd-4550.c:139:Warning [2054] suspicious pointer conversion
C:\Documents and Settings\WHW\Desktop\prj\LCD_X\lcd-4550.c:140:Warning [2054] suspicious pointer conversion
C:\Documents and Settings\WHW\Desktop\prj\LCD_X\lcd-4550.c:141:Warning [2054] suspicious pointer conversion
C:\Documents and Settings\WHW\Desktop\prj\LCD_X\lcd-4550.c:142:Warning [2054] suspicious pointer conversion
C:\Documents and Settings\WHW\Desktop\prj\LCD_X\lcd-4550.c:143:Warning [2054] suspicious pointer conversion
C:\Documents and Settings\WHW\Desktop\prj\LCD_X\lcd-4550.c:144:Warning [2054] suspicious pointer conversion
C:\Documents and Settings\WHW\Desktop\prj\LCD_X\lcd-4550.c:145:Warning [2054] suspicious pointer conversion
C:\Documents and Settings\WHW\Desktop\prj\LCD_X\lcd-4550.c:146:Warning [2054] suspicious pointer conversion
C:\Documents and Settings\WHW\Desktop\prj\LCD_X\lcd-4550.c:147:Warning [2054] suspicious pointer conversion
C:\Documents and Settings\WHW\Desktop\prj\LCD_X\lcd-4550.c:148:Warning [2054] suspicious pointer conversion
C:\Documents and Settings\WHW\Desktop\prj\LCD_X\lcd-4550.c:149:Warning [2054] suspicious pointer conversion
C:\Documents and Settings\WHW\Desktop\prj\LCD_X\lcd-4550.c:150:Warning [2054] suspicious pointer conversion
C:\Documents and Settings\WHW\Desktop\prj\LCD_X\lcd-4550.c:151:Warning [2054] suspicious pointer conversion
C:\Documents and Settings\WHW\Desktop\prj\LCD_X\lcd-4550.c:152:Warning [2054] suspicious pointer conversion
C:\Documents and Settings\WHW\Desktop\prj\LCD_X\lcd-4550.c:153:Warning [2054] suspicious pointer conversion
C:\Documents and Settings\WHW\Desktop\prj\LCD_X\lcd-4550.c:154:Warning [2054] suspicious pointer conversion
C:\Documents and Settings\WHW\Desktop\prj\LCD_X\lcd-4550.c:155:Warning [2054] suspicious pointer conversion
C:\Documents and Settings\WHW\Desktop\prj\LCD_X\lcd-4550.c:156:Warning [2054] suspicious pointer conversion
C:\Documents and Settings\WHW\Desktop\prj\LCD_X\lcd-4550.c:157:Warning [2054] suspicious pointer conversion
C:\Documents and Settings\WHW\Desktop\prj\LCD_X\lcd-4550.c:158:Warning [2054] suspicious pointer conversion
Executing: "C:\mcc18\bin\mplink.exe" /l"E:\MCC18\lib" /k"E:\MCC18\lkr" "18f4550.lkr" "lcd-4550.o" /z__MPLAB_BUILD=1 /m"lcd4550.map" /o"lcd4550.cof"
MPLINK 4.1, Linker
Copyright (c) 2006 Microchip Technology Inc.
Error - Configuration settings have been specified for address 0x00300000 in more than one object module. Found in './lcd-4550.o', previously found in './LCD-4550.o'
Errors : 1
Link step failed.
Release build of project `C:\Documents and Settings\WHW\Desktop\prj\LCD_X\lcd4550.mcp' failed.
Mon Sep 20 08:29:05 2010
BUILD FAILED
