I have been working to modify an air popcorn popper so that the temperature of the heating element is a little lower so I can roast coffee. I have tried putting a few different things in-line with what is labeled "Thick white wire" on the schematic. I first tried a household light dimmer. Unfortunately, it didn't give me adjustable temperature. It was on at maximum "brightness" and turning it down a tenth of a millimeter (and lower) was off. Due to the price of potentiometers that can handle some wattage ($55+), I then tried a 0.2 ohm wirewound resistor. This worked, although it got very hot, but the temperature reduction was not enough. My latest attempt was with a 25W 0.47 ohm resistor, which seemed to be just about right, but it got way too hot (solder softened). So, now I am wondering about other methods of accomplishing my goal.
I am aware that diodes can sometimes be used for this purpose, but I think I've only seen that mentioned in the context of low voltage DC circuits. Same for PWM circuits. In both cases, I haven't seen anything to indicate those are good approaches, or would work at all, for my 115V, 60Hz, 13 amp AC situation. (The Large Heating Coil is about 13 ohms, btw.)
Can someone recommend a good approach that isn't too expensive? Ideally it wouldn't get hot at all. I have a general question which I haven't really looked into, which is, why are resistors used so much when their very purpose is to waste power. It's worth some money for learning experiences, even if it isn't for my solution, per se.
