Hi Folks.
I will try and give as much information as I can without it turning into war and peace mk2.
I have an old Mephisto Chess Computer that were very popular back in the day and can still be seen for sale on the bay etc.
It consists of 2 separate units, 1 is the wooden electronic board with all the pcb circuitry and the other is the black control unit which has the processor, input pad and LCD display. (Please see uploaded pictures).
The black computer unit can be either used as a stand alone item to play a game against or it can be connected through the flexible ribbon cable to the wooden board and moves can be input by the magnetic chess pieces through reed switches directly under each square.
When playing just against the black chess computer module the power supply is connected directly just to it.
When playing with the black chess computer module and the auto sensory wooden board the power supply is connected to the wooden board and the black unit to the board by the ribbon cable as per above.
Until recently it has worked just fine in either mode, recently however it will only work when the black chess computer is being used on it's own.
When connected to the wooden board it starts up okay but after about 15 minutes or so into a game the LCD display characters quickly start to dim and either break up or fade out completely and I have tried 3 different power supplies which are all to specification and the same happens. If you leave it for a couple of minutes and turn it off and back on it starts up okay again and just repeats the fault cycle.
This would seem to indicate the problem lies somewhere on the on the wooden board electronics.
Finally the question is, "Where to start looking, out of all the components which would cause the power from the wooden board to the black chess computer unit to fail after 15 minutes and cause the LCD to fade out or lock up?"
I hope this all makes some sense and If anyone can point me in the right direction towards suspect parts it would be greatly appreciated.
Thanks. Mart.
Thanks. Mart.
