Frank,
I'm not familiar with 'Maxsea', but don't think that's the problem
anyway. As far as I'm concerned, MS never did get a grip on memory
management, but that's another story. :^)
You might want to try this: First thing, note how many icons are in
your system tray (the one on the far right). If you see icons for
programs you don't need running, you want to get rid of these. For
example, if you've instaled Realplayer, it will start a process
every time your computer comes up. You don't need to have this
process running on your system 'at all times'. Realplayer will still
work fine. So what if it takes an extra second to start up when you
want to play a media file. In that case, you can right click on the
icon and get into the preferences and have it NOT load on system
startup. If you only click exit, it will still load on the next
startup/reboot. If you have CD burning software, chances are, when you
installed it, several more processes were added. Especially if you've
installed something like Roxio.
To clean things up that you can't turn off in the system tray and have
them stay off, next try this:
Click on 'start', then 'run' and then type 'msconfig' and hit enter.
In the box that comes up, choose the 'startup' tab at the far right.
Oh, before I go further, unless you're comfortable with what is in the
other tabs, DON'T EVEN THINK about changing aything in them. :^)
Now, look at the list and uncheck anything that you don't feel you
need running all the time. Leave stuff in there if you do want running
at all times. Examples are any programs/processes associated with you
virus protection as well as any programs/processes associated with a
software firewall, if you're running one. After fininshing, click on
'apply'. You will next be prompted to reboot for the changes to go
into effect. If you're ready to try this, go ahead and reboot. Note,
when the system reboots, a diaog box pops up stating that you are
running 'selective startup' (if memory serves me). Just check the box
to not show you the message again. You already know you made changes.
I hope this helps! I strongly suspect this will get you going with
Maxsea. Please post a reply either way.
-Jim
