[MELB] HP A2094A monitor (Sony GDM-1934) for anyone interested
Dave
G'day folks, if repair techs, etc, are interested in the above 20"
monitor they can have it as long as you can pick it up, (I'm on Mt
Dandenong).
I think it's a GDM-1934 variant, (after doing a Google search), it's
fixed frequency, 1280*1024 72Hz 78.125kHz 5*BNC,(R,G,B,HD,VD), inputs &
outputs.
It might have a problem, I couldn't get it to sync to my PC output when
set to 1280*1024 72Hz, but the Trinitron tube seems to be fine - at
least what I could see of it as it was trying to sync.
Anyone interested in doing a swap for approx. 4 high voltage film
capacitors?
Otherwise I'll start pulling it apart to see if I can get the parts I
need for another Trinitron monitor - or if someone can send me the parts
list for it from the Service Manual, I can see if it has the parts I
need without pulling it apart.
Thanks,
Dave
Clifford Heath
How did you inject the sync? These monitors mostly take sync on green.
I've had success operating workstation monitors from a VGA card under
Linux (where I have complete control over scan settings) by hooking
the Vsync and Hsync to the Green via a pair of 220 Ohm resisters.
The video level is a little low, so you can't quite get full brightness,
but that doesn't bother me, in fact I'm looking at an HP98752A
(rebadged Sony) right now.
Clifford Heath.
Dave
I thought of that and have a small cct diagram for combining H & Vsync
to give sync on green but couldn't be bothered trying it - was a bit
more than a pair of resistors :)
I just used the VGA->BNC cable, guess I could try puting the resistors
on the back of the BNC connectors just so I can see if the monitor does
indeed work properly but in the end I'd rather fix my IBM P70 multiscan,
(Sony 17SE2T - reduced width problem), than be stuck with just one
resolution/scan rate - also the P70 isn't quite so cumbersome!
Suddenly got into this fix all the gizmos mode:
NEC N9570A - requires idler assembly
NEC 3D - replace all the electros (vertical foldover)
IBM P70 - reduced width (try to replace HV caps - if I can find
them)
Sony SLC40ES - tape take up not quite working fast enough
Couple of TEAC VHS recorders found during hard rubbish that require a
bit of mechanical tweaking but otherwise record and play fine - the
things people throw out. Still using a perfectly good microwave that
someone threw out - couldn't have matched their new kitchen!
The fun never stops :)
BTW, if anyone can help, the 17SE2T manual lists some caps as:
C432 1-113-714-11 FILM 2000pF 3% 2KV
Anyone know where I can get caps of that spec, (besides genuine Sony
parts), bearing in mind I only want small quantities, (ie. 1 or 2 of a
value)?
Also, when they say 'FILM', exactly what construction are they talking
about?
Looking at them I'd say polypropylene, which are suitable for the H
output section.
Dave
Clifford Heath
Wouldn't mind seeing that - got a scanner or an electronic version?
I run Linux where fixed scan isn't a problem, but even on Windoze
if you use a dual-screen adapter a fixed-scan monitor works well as
a 2nd screen.
More-or-less what I did. Use -ve sync for both H and V.
I bought a pack of 3Kv caps from Oatley a while back with the thought
of building a Cockroft-Walton voltage multiplier for an ion generator.
Never bought the diodes though. They're marked "B 152K CM04", so I
guess that's 1500pF, pretty close to what you want. You're welcome to
a couple if you pick them up (email heaths08 at optusnet dot com for
location, Melbourne ES). Or I could drop a few in an envelope.
about?
Dunno, but not many types are made for that V rating, and I guess that's
what matters.
Clifford Heath.
Dave
GIF file, I'll send it to the address you've given below.
a 2nd screen.
That's what I'm testing it with, (ATI Radeon 9600 as the 2nd monitor).
Under the display properties, (as I just discovered), I can set max
vertical freq. (72Hz), max. res. (1280*1024), the HSync/VSync polarities
and also composite sync. However, none of these provide compatibility
with sync-on-green monitors, (according to ATI WWW site).
But, (I obviously wasn't awake during my last reply), it shouldn't be
needed since the monitor has inputs for HSync and VSync and I have the
correct cable VGA->5*BNC. Sync-on-green would only be needed if I only
had basic RGB, (3*BNC), inputs.
Indeed, there's a website telling you how to mod a Sony GDM-1960/61 just
by adding 2 more BNC sockets for HSync/VSync and a couple of resistors -
apparently there are places on the input board just waiting for these
components. It also has a link to another sync-on-green adapter.
In case you're interested:
http://vmlinux.org/jocke/mirror/www.geocities.com/SiliconValley/Foothills/4467/fixedsync.html
BING! Just realised, that page actually mentions a HP98752A, sound
familiar :) success story done WITHOUT a sync-on-green adapter with
Win95 - you may be able to set the monitor specs in Linux up the same.
However, no matter what combination of sync I try, the monitor won't
oblige - I can almost get it to do it if I play around with the Low
H.Freq adjust on the main PCB, (they even supply a service tool in the
monitor!).
I've created space on the HD and will install Linux, (been a while since
I used it last), and see if I can get it to work with that.
Thanks for the offer, I'll see how I go, got to make a list of
everything I need for these repair jobs then see what I can get on my
next journey "down from the mountain" :)
Dave
Craig Hart
note original post: *5* BNC inputs - R,G,B,*VS*,*HS*
Similar threads
