First, the context. I'm trying to make an FM transmitter circuit that is capable of transmitting on medium distances (clear signal up to 500 meters/1500 feet), so that I can listen the music on my PC wherever I am around my place. I'd also like to use it as a private radio station for me and my friends.
Now I'd like, if possible, to start from the following medium power circuit that can transmit up to 100 meters (and adapt it for a computer stereo speaker output):
This raises a series of questions:
Additional questions (added after initial post):
That's all for now, but I'll probably come up with more in time. Thanks in advance!
- Can I amplify the signal from the above circuit instead of using another one?
- If yes, are there any losses in sound quality and such?
- How do I know the exact frequency I'm transmitting on (check C6 on the diagram)? [ANSWERED]
- Can I simply plug the microphone wires from the circuit to the stereo speaker jack? [ANSWERED]
- How do I prevent my computer's sound card from being toasted (by the additional 12V power supply)? [ANSWERED]
- Do I have to add a resistor to bring the power lower? (the 12V from the power supply + the few volts from the stereo speaker output add up to more than necessary) [ANSWERED]
- Will the above circuit transmit the signal as stereo, or will it be converted to mono? [ANSWERED]
- How am I supposed to ground the circuit? [ANSWERED]
- Can I power the above circuit from AC without using a rectifier? [ANSWERED]
- Would it be hard to encrypt/decrypt data somehow before sending/after receiving it (even better if the encrypted data sounds like background radiation)?
