Hi, I bought recently a second hand oscilloscope (Hameg 1005 100 MHz) which came with 100MHz Textronix probes. I noticed that displaying waves that gets closer 1MHz becomes almost impossible task. I use 'hold' variable to 'freeze' a wave normally, but when for the waves with hight frequencies the variable becomes not very sensitive and even a small variable turn will cause the trace run faster until impossible to see the actual wave.
I have checked if the probe are 'calibrated' by connecting the probe to the internal square wave generator of the oscilloscope and then inspecting if the edges of the waves were straight.
Could that be a fault of the oscilloscope or the probes have to be from the Hameg too?
