I have one doubt in the below circuit, the circuit is for measuring the current
I have not put in all the components, but the gain of the opamp is around 15. When the current is 0 i read at the output of the micro 1.65V.
When the current is flowing from Point A to Point B the voltage at the micro is greater than 1.65 and less than 3.3V. It is called the positive current?
When the current is still flowing from point A to Point B the voltage at the micro is less than 1.65V and above 0V. It is called the negative current?
Is the understanding correct? My main question is either the current is positive or negative the flow is from Point A to Point B? How is it possible? For negative current it should flow from Point B to Point A? Please advise.
