Mike Deskevich
I have a question about measuring the average voltage being delivered
to a circuit. Basically what I want to do is tap into the line coming
from the ECU to the fuel injectors in my car. The ECU sends a pulse
signal to the injector to signal the injector to open and start
spraying fuel into the intake. I figure that if i can measure the
average voltage on this line then i can know what percent of the time
the injector is open. then knowing the fuel delievery rate of my
injector and my speed i should be able to calculate an instantaneous
gas milage value. Eventually i'm going to do this digitally with A/D's
and a LCD output so that i can monitor a number of variables. But
right now i want to do it all analog. That it's I'd just like to have
a (analog) voltmeter that reads a voltage that is proportional to the
average voltage being sent to the injector. I figure that for high
frequencies that any typical analog voltmeter is going to read the
average voltage, but what happens at idle when the frequency is going
to be something like 4-8Hz? does a typical analog voltmeter average
over that range too or does it start to look DC at 8Hz?
(for the car experts out there: i can't use OBD-II and get this info,
as my car is an '89 and predates OBD-II by many years).
if anyone has any ideas that would make my life easier, i'd appreciate
it!
mike
it!
mike
