Don Y
Hi Mike,
Well, I dug up an electronic ToU KWHr meter I designed many
years ago and tweaked the gain of the front end -- better
suited to "a few amps" instead of a few *hundred* amps.
Then, measured the PC with that *and* the current clamp
(using the ToU meter as a "sanity check" on the readings
from the current clamp).
Numbers were similar -- though *higher* than your above:
100 - 140W (idle, active). I didn't bother with "sleep" or
"off" power levels as I am only concerned with the worst
case numbers.
If I can find the optical programmer, I bring the ToU meter
back and configure it to report peaks -- then see how I can
*create* those peaks.
I was expecting the monitors to be ~20% less and was
surprised to see them come in at almost this exact same
figure (despite being much smaller -- 19"). So, I'll need
to rethink whether I should recommend dual monitors on
each workstation or just go with one. I could also point
to the extra counter space that they would consume. But,
the killer is having to support another KW! Sheesh!
(also makes me wonder what I'm drawing in my office with
6 monitors on! :< )
The devil is in the details.
Based on the Kill-O-Watt recommendation below
Here's what my 2.8GHz. quad-core intel does.
State Watts Volt-amps
off 3 7
booting 120 174
Idle 88 132
Sleep 10 20
A newer system would more likely have a power factor
corrected power supply. I don't have anything that new.
case numbers.
That doesn't include either of the two 24" monitors.
93W 95VA each.
6 monitors on! :< )
