Measure distance behind walls
G
Giorgis
Is it possible to measure distance, even behind walls to a few cm
accuracey over 50m ?
Regards
Giorgis
Joel Kolstad
If you want to go through walls, how did you intend to define the endpoint for
your distance measurement? Are you thinking between, e.g., a transmitter and
receiver that might be on opposite sides of a wall?
G
Giorgis
Yes lets say I would like to mwasure the distance between the corners
of my house with no line of sight. Only with two devices at either end.
Is it possible
George
Paul Hovnanian P.E.
Is it possible
Possibly, with DGPS. It depends on how clear a view of the sky you have.
Tim Auton
Theoretically radar at the right frequencies could do what you want. You
might want to look at Ground Penetrating Radar, which does something
similar and is in use in the 'real world'. If you want to do it without
a big (military, corporate, research...) budget I think you're out of
luck.
Tim
Sjouke Burry
Is it possible
George
A dgps unit with distance travelled between
waypoints.
G
GM
Regards
Giorgis
Bre Giorgi 3erola pws sou 3efuge auto :))))) ???
G
Giorgis
Giati re su, eee eimaste kai an8ropoi kai meis :)
Giorgis
PS: Pou na deis ton 3adelfo mou ton Mporola
G
GM
Giorgis
Pantws gia to 8ema des gia RF lush me kateu8untikh keraia. Pisteuw pws
metrontas to attenuation tou shmatos (pou 8a exei se megalo ba8mo logw tou
teixou) mporeis na bgaleis kapoia sumperasmata. Se kapoio ma8hma gia mobile
comms eixame kanei kapoia montela gia attenuation se shmata khniths thl/nias
sumfwna me to path poy eperne to shma (mesa apo ton aera, anaklaseis, mesa
apo teixous) kai uphrxan kai parametroi gia px teixous me paxos W. Bebaia
auta ta montela htan empeirhka kai eixan efarmogh se susthmata kinhths
thl/nias opote mallon 8a prepei na peiramatisteis kai na bgaleis kapoio diko
sou montelo metrhsewn. Distuxws den eimai eidikos se RF opote den 3erw na
sou pw kati sugkekrimeno
Giwrgos :)
PS: Xairetismous ston Mporola xexe :p
Rich Grise
Is it possible
Yes, for very large amounts of money.
Why not just pick a third point, visible from both A and B, call it C,
and just trig it out?
/ _____ \
A [HOUSE] B
[_____]
Measure the distances AC and AB, and the angle ACB, and it should be just
arithmetic from there.
Good Luck!
Rich
G
Giorgis
Giwrgos :)
Endiaferon ... se RF exw gnwseis xombi. Exw omws kapies par3enes idees.
8a doume.
Euxaristw, nasai kala
Xeretismata apo Sydney Australias
Giorgis
G
GM
8a doume.
Giorgis
Xereismous apo A8hna ;-)
Giwrgos
