Hi!
What is the meaning of the words next to the ganged switches in the green and red rectangles?
I know that ukw is fm, mw is mediumwave, lw is longwave and kw is shortwave.
The buttons in the red square are very strange, they can be pressed (if you press one, the other one that has been pressed pops out) and also you can rotate the black cover around it and a mini-scale will move. Each scale is marked u1, u2, u3, u4 and u5 (the u afc is a switch that if you rotate clockwise it goes red, counter-clockwise it goes blank).
Another strange thing is that if you're on a station on fm and you press u1 u2 u3 u4 or u5, it changes the frequency (it isn't some kind of memory, in the service manual it is marked "soundboard")
Thanks!
Thanks!
