Hi
I am playing with the MCP73831 Li ion charger ic.
I have used the example circuit as per the datasheet and it is built on a professionally made PCB, however i am having a couple of problems that im a little stumped on.
The charger itself works but im not sure that its correct.
Source voltage is regulated 5v power supply. However when connected to the charger it drops to 4.85v
The output voltage from the charger is 4.05v where it should be 4.2v
When the battery charge voltage reaches about 4v the status led flickers. I cannot find any info relating to this error.
Has anyone used this chip that may have any suggestions as to the problem.
