Hi.
Once I used max713 to make a charger for my cordless screwdriver, the original B&D had a "class 2" charger consisting of a single transformer outputting 5vAC. For this project I used a wall adapter to get suitable output voltage for the max713 to use. That was a while ago.
This time I intend to use my small PV installation consisting of a pair of 65W panels which charge a 100AH 12v battery and power a well pump. The output voltage, while charging the battery, varies between 11.5v-13.5v depending on the charge of the battery. I need to charge the NiMh cells in packs of 4, since I use them in 2 portable radios.
Since the input voltage for the max712 would be 1.9*4+1.5=9.1v, I will have surplus of voltage here, I am not sure how to approach this. Should I set the charging rate lower and just use it like that or use another solution?
Please advice.
Thanks.
Please advice.
Thanks.
