Hi guys, I'm back with another faulty unit. This time it's a Martin MP-2000 fog machine, a really big unit used to fill large stages and clubs with dense fog. The unit consists of a remote control which plugs into the PCB and a 110V heating element and a 110V pump which pumps the fog fluid into the heater to create fog when the heater reaches the correct temperature after heating up. There is also a sensor which connects from the heater to the PCB to send a signal when the heater reaches the correct operating temperature. The remote plugs into the rear of the fog machine, into the PCB and, when the unit is switched on, a red power LED lights on the remote and two red LED's light on the PCB, "Power On" and "Heat", signalling that the unit is powered on and the heater is heating up. The green "Ready" LED comes on when the heater reaches the correct temperature and fog is produced by pressing the "Smoke" button on the remote. Based on everything I've learned concerning repairs from you guys, I think the BTA12 Triac will supply the pump and the BTB24 will supply the heater which has a high amperage draw and the 7805 supplies 5VDC to the PCB via the 110V/10.5V transformer. And that's where my smartness ends...... The PCB with issues does not function at all. When I connect it to a known working unit, the red "Power on" and "Heat" flash intermittently which indicates an error, and the machine does not go to the "Ready" stage. Where can I start?
Platforms
Content
