Manchester Decoder
Jim Thompson
Anyone have a simple-minded design for a Manchester Decoder?
Thanks in advance!
...Jim Thompson
John Larkin
Thanks in advance!
...Jim Thompson
If you detect transitions of either direction, and fire a
non-retriggerable one-shot of 0.75T duration, you'll recover an
unambiguous clock. The rest is easy.
John
Jim Thompson
John
"transitions of either direction" ??
Now I'm lost :-(
Please elaborate for the analog guy ;-)
...Jim Thompson
PeteS
Now I'm lost :-(
...Jim Thompson
Manchester encoding has:
The line always transitions in the middle of the bit. If some bit(n) is
the same as bit (n-1) then do _not_ transition the line at the start of
bit n. If bit(n) and bit(n-1) are different, then transition the line
at the start of bit n.
As there's no guaranteed transition (low - high, high - low) at any
position, the way to recover the clock is to capture both transition edges.
So to paraphrase John, set up a non-retriggerable one-shot with 0.75T
and make it trigger on a high-low _or_ low-high transition direct from
the data.
Good picture at http://en.wikipedia.org/wiki/Manchester_encoding
There are one-shots with dual triggers available. Try this one for size:
http://focus.ti.com/docs/prod/folders/print/cd74hct221.html
Cheers
PeteS
PeteS
the data.
Cheers
PeteS
I'll admit to a major brainfart
The encoding is:
If zero, then the bit will transition from high to low in the middle of
the bit, and a one will force a transition from low to high in the
middle of the bit.
My apologies (my mind was on something else I am in the middle of doing)
Cheers
PeteS
L
Luhan
John
'Pure' Manchester code can have pathalogical groups of zeros or ones
making decoding impossible. You also need to either use either Async
(start and stop bits), or Sync (leading known sync byte) to be able to
decode reliably.
Luhan
L
Luhan
decode reliably.
Luhan
Now that I recall, my earliest one loaded an assembler program into a
wirewrapped 8080 machine using a version of Manchester. The only
hardware was a single comparator connected to the headphone jack of a
portable cassette player. This fed a variable width bit directly into
an input port. The decoding (as well as the encoding) was all done in
software.
Luhan
petrus bitbyter
Now I'm lost :-(
...Jim Thompson
Well, Jim,
Suppose the digital logic is below your imagination. To make things easier
an every day example. It's like an airplane: When it's down it may go up,
when it's up it will go down. No other directions available :)
petrus bitbyter
F
Fred Bartoli
John Larkin a écrit :
If that's too simple, just think it at the transistor level :)
Martine Riddle
Thanks in advance!
...Jim Thompson
Check OpenCores.org. I believe they have an open Decoder in VHDL.
Cheers
John Larkin
What's VHDL? Does it have a VBE ?:)
...Jim Thompson
Very Hard to Deceipher Language. It's a way to make a simple schematic
into scores of pages of gibberish.
John
Jim Thompson
John
<Smirk>
...Jim Thompson
L
Luhan
Thanks in advance!
In the early days, Tarbel Electronics produced cassette interface
boards for S100 computers. They used a modification of the Manchester
code. 1's produced a full cycle at the clock frequency, 0's produced a
half cycle at half the clock frequency...
Decoding was more deterministic. You got a 'carrier' of all ones
(clock) followed by an initial zero (start bit) which was easily
detected being twice as long (independant of phase). The data was
decoded as async bytes with 2 stop bits (to give your software time for
storage and other overhead).
This was the system I duplicated on my 8080 system. It got one hard
error in the first year of operation using a standard audio cassette
deck.
Luhan
