Mallory Recto Power supply
tweak
I have a really old benchtop power supply, an Mallory model 12RS6D
6/12 volt power supply.
When I dug it out of storage I noticed the cap to the fuse holder as
well as the fuse was missing.
Does anyone here know what rating fuse this unit takes?
I tried a web search for Mallory with no luck.
I can post additional specs on this unit.(volt/amp rating etc...) if
needed.
Thanks in advance
none
needed.
Thanks in advance
Learn how to crosspost instead of multiposting.
Fuckhead.
tweak
Fuckhead.
What's the difference twit.
It's just a matter of efficiency/convienence.
You'd not use that language if you had to converse face to face.
Which tells me your just some lame ass punk cruising for an ass
kicking.
Tweetldee
needed.
Thanks in advance
Any idea as to the current capacity of the power supply? That would help
in determining a first-shot estimate of the fuse rating.
*timber*
Greetings tweetldee,I need your help sir,
I spyed an old Davis 808 amp on Ebay that had 4 6l6 and 3 6eu7's ,a
12bh7a and dual 5u4's and finally it has a power output and filament
transformer.I bought it.I also need a schem of this monster. as the
circuit is not complete (semi gutted).The transformers are all good
and quite large.I was going to mod it to a a laney guitar amp
circuit.The problem I have is I mesured the voltage coming from the
power xformer and it mesures 430 volts each of the two red leads the
brown leads mesure 335 each brown lead it also has a red/yellow tap
and brown/yellow tap.Can you tellme what the browns were conected
to?also the b+ appear very high for my plans.What is the B+
measurement on your amp? Any info would be greatly appreciated .
Regards,
Chris
PS
I can't email you as it gets returned.
