Joel Kolstad
Just curious... if you're trying to use a bi-color (red/green) LED to make
yellow, how well does it work using an LED with a clear "lens" along with a
(clear) light-pipe (mounted above the PCB, going through the case)? I've used
diffused LEDs in the past to do this with no problem, but I'm thinking that
with a clear lens there won't be enough mixing of the red and green and the
user will just perceive the two distinct colors rather than yellow as
intended. Thoughts?
Given a choice of packages (e.g., 1210 vs. 0605), presumably I'd want the
smallest one available so that the red and green LED chips are as close
together as possible, right?
Thanks,
---Joel
intended. Thoughts?
Thanks,
---Joel
