Roger Breton
Can I use a radiometer like a Tektronix J16 to make power measurements from
the sunlight? In Watts?
Roger Breton
Roger Breton
Roger Breton
What aspect of sunlight are you trying to measure? Most of the probes
for the J16 are photopically corrected so they will give lumens or
candelas per M^2. The J6502-A/J6512-A probe is an irradiance probe
that reads in mw/M^2. However, it is flat from 450nm to 950nm and down
50% at 400nm and 1030nm, so it will not read all the energy emitted
by the sun. The upper limit without use of a neutral density filter
seems to be 2mW/cm^2.
I don't think the J16 is the right instrument for measuring the power
density of sunlight at the surface of the earth, if that is what you
are trying to do. I would suggest that you use a broadband radiometer.
by the sun.
By the way, what is wrong with it 'being flat'?
Roger Breton
But I am not interested in the measurement of how much power fall per
unitary area at the stage of learning radiometry I am (I know I eventually
will) but how to measure *raw* radiating power from a source, in Watts, and
how much power per unit time this source radiates, in Watts/sec. How can I
get my feet, and those of my students, in this area whithout breaking my
bank (which is already half broken by now)?
What I am trying to do, as usual, is to push the boundaries of my ignorance.
As I am studying radiometry these days, I read up on climatology and how the
sun is radiating its power to the earth (I had no idea there was such a
thing called 'the solar constant'!). I figure if I can understand how to
measure the sun radiating power then I'll be able to generalize the concepts
to other sources of radiation, namely artificial light sources. All colors
start with light and to study light I need to understand the concept of
radiant energy (eventually spectral radiant energy). These are not trivial
physical concepts to grasp. I figure my best bet, right now, is to study how
to measure radiant energy (flux), because once I understand that much then
moving to photometry (and later coloriimetry) is just crossing into V-lamba
territory -- I'm probably oversimplifying to death (?). I often see these
Tektronix J16 instruments come up for sale, used, on eBay for dirt cheap. I
am not interested in their photometric measuring capabilities but in their
radiometric capabilities which I did not know existed until yesterday. Hence
my post. To adequately measure the sun radianting power I probably need and
irradiance measuring device which will give me Watts/m2 or microWatts/cm2.
Regards,
Roger Breton
Flat is good. I should have said "... flat ONLY from 450nm to 950nm."
OK.
You need a radiometer that is has equal response to all wavelengths
from about 305nm to 2500nm
place your radiometer above the atmosphere. So, unless you have good
connections at NASA or the Russian, European of Japanese space
programs, you have to settle for measuring the sun through the earth's
atmospheric filter.
Second, even if you could get above the atmosphere you would need to
completely surround the sun with detectors to DIRECTLY measure the
total raw radiation of the sun. This is rather impractical, to say the
least, and is even impractical for most conventional light sources.
For the sun, you can assume that the radiation is isotropic,
measure
the power per unit area at your detector,
and then multiply that
result by the area of the virtual sphere defined by your
sun-to-detector distance.
To measure the total output of conventional light sources they are
most often placed inside an integrating sphere that takes the
non-uniform output of the source, and through multiple diffuse
reflections, distributes this energy uniformly over the inner surface
of the sphere. A measurement is made with a small detector that can
then be converted to total radiation by multiplying the energy
received by the ratio of the sphere area to the detector area.
In practice, however, the measurement is not made this way due to the
fact that the surface of the sphere is not a perfect reflector. The
sphere is usually calibrated using a lamp that has been measured and
certified by the National Institute of Standards and Technology (NIST)
and then the output of the subject lamp is determined by comparing the
reading of the detector when the NIST calibration lamp is operating to
the reading when the subject lamp is operating.
Or ... instead of using an integrating sphere, you can measure the
light at each position around the subject lamp using a goniometer (in
a black room) and the summing all the readings.
No, I am afraid I don't have such useful connections
How about, theoretically, enclosing the sun in an integrating sphere: would
I then be able to measure through a port like you describe below?
Isotropic as in 'equal intensity in all directions'? I've many times
encountered that word but I never clearly understood its meaning.
Yes.
Please correct me if I am wrong but doesn't measure the 'power per unit area
(of the detector)' equate to measure the irradiance? E.g. Watts/m2
The area of the virtual sphere? You mean to infer the sun's irradiance from
a single power measurement and then extrapolate that measurement to the
whole surface of the sphere to find the total power of the sun irradiance
within a certain radius around it?
Well, that seems exactly like what I was trying to describe above, just more
elegantly. So the ratio of the sphere area to the detector area multiplied
by the power measured on the detector area gives total irradiance on any
sphere surface? That is in theory, I gather from reading below.
OK, I understand the measurement is not made 'this way' because no sphere
are perfect reflector (even with Spectralon or other special material?).
Then, some other reference is used to infer the true measurement of power
from a given sphere. So this is an indirect method of measurement but one
that uses a 'standard'. But I wonder how NIST can determine their lamp
calibration in the first place if they too are stuck with sphere that are
not perfect reflectors?
Victor-
Is the equal response capabilities of the radiometer itself or the detector?
Roger Breton
Roger said:How about, theoretically, enclosing the sun in an integrating sphere: would
