I
Impmon
I wanted to build something akin to mini neon sign like those in Las
Vegas or the Time Square in NYC but on small scall. conventional neon
are too large and too inefficient. CCFL could work but inverter that
comes with CCFL tended to be cheap and can blow out easy from
switching a lot. Plus CCFL are rarely available in any form other
than straight.
LED is low power, cheap, and won't burn out from switching frequently.
But LED bar I've seen seemed to be made of multiple LED in a line and
I don't want the spotlight effect. So that leaves light pipes with
LED at each end.
Can any of you suggest a simple materials that I can use, available at
local places, and easily bends to form shapes? Clear inside, frosted
coating would probably mimic mini-neon tube the best. I've thought
about using hot glue to make light pipes but they may not be clear
enough to allow light to travel the full length.
TIA for any advice or suggestions.
than straight.
LED at each end.
