Just out of curiosity, is
this relevant?
I ask you this because we have had a number of people come here and ask pretty much the same type of question that you asked, however I've never been certain about the level of the course, so I really don't know what to suggest.
If that document is relevant, then it appears that design is the important issue. Are you going to write a set of requirements based on the specifications of the circuit you have found? It might work, but you're doing it backwards.
If you decide the problem is that "I can't have several people listening to my iPod". Then your next step is to research the available outputs from the iPod and their levels, then determine what power is required for "comfortable listening", then go off in search of something that will transform one to the other. You may end up in the same place, but you'll probably have a more credible piece of work to hand in. Also your teacher *should* probably reject a proposal that comes with the solution but not the initial design -- but maybe standards are dropping...
My school project was an "electronics workbench" which was basically a wooden surface with an enclosure at the rear to hold a power supply, a signal generator, and amplifier and a device which allowed an audio signal to appear on a TV (a-la CRO). All of the design except the TV-CRO adapter was my own. The design brief covered ergonomic issues (such as the size of the workbench to allow easy reach of all controls), electrical safety (yes, it had 240V wiring), and various specifications that had to be met. Sure, for one power supply I pretty much knew I was going to use a 723, but because I started from specs, the final design was substantially different from the initial concept.
I guess I have high expectations for school projects.
edit: it was *many* years ago...
