Anyone know of a good way to make connections modifiable on a PCB? What I have been thinking is making a small break in traces. So a trace will end in a through hole, then begin again a few millimeters away with the trace starting up again with another through hole and going to its final destination. A solder bridge or a jumper could bridge the gap and if it needs to be changed a wire could go from one of the first through holes to a different second one.
I ask because I'm making a PCB that has lots of single connections from about 20 pins to 20 other pins. I'd like to be able to change which ones are paired. Normally they will be not need to be changed so pin#1 in the first set will usually be connected to pin #1 in the second, but situations may arise where things would need to be changed. It is even possible that they would need to be changed a number of times but that is probably not that likely.
Any experience with this kind of thing or any ideas? Thank you so much!
