Making a high speed pulser
Hi, all.
I need to pulse each sensor in a stack of of roughly 1500 sensors. There has to be about 20 microseconds in between pulses, or else my 100khz counter will lose tract. I tried using a LDR that fired a LED... which in turn fired the next LDR and so on. With a small cap in each branch I got this method to work, but LDRs fire way TOO SLOW. Using this method would take 75 seconds to count up all the sensor inputs. I ONLY have 1 second to do this scan. I am COUNTING inputs, NOT timing the whole scan.
I want to try replacing the LDRs with photodiodes in the above circuit. But I am afraid they are TOO fast for my counter to keep tract of. I am not going to go the 555 timer route. I would have to solder in 166 of them.
Any help would be greatly appreciated.
davenn
Hi, all.
Everyone
Before you respond, have a read of this thread
https://www.electronicspoint.com/threads/help-connecting-555-timer.280492/#post-1706662
that I closed some time ago when not enough clear info was supplied and the thread got out of hand with wild guesses
because @RobertB50 didn't return to supply better info
The moderators will monitor this thread to make sure it doesn't go the same way
@RobertB50 please supply some drawing of how you expect this to be connected up etc
Dave
